2nd Gear Chirp
Posted: Tue Jul 29, 2003 10:19 am
by JustinVGT
I've just been wondering how some of you have mentioned when racing or accelerating quickly, you can chirp your tires when shifting into second gear. I still have not been able to do that. Is there some trick to your shifting? When I am accelerating quickly I take it up just about to the redline and push the clutch in, slam the shifter into second, and let the clutch out as quickly as possible. Do you slip the clutch when letting it out? I don't want to add too much excessive wear and tear to the clutch, especially with some saying their clutches are going out early. Thanks,
Re: 2nd Gear Chirp (JustinVGT)
Posted: Tue Jul 29, 2003 11:02 am
by savedbyzero
I would say it's actually good that you're not. But if you want to do it, drop the clutch hard at the top of first into second...CHIRP!
Posted: Tue Jul 29, 2003 11:16 am
by philndz
lay on the gas before you actually drop the clutch and make sure you drp the clutch at between 3000 and 4000 rpms and you should get serious bite!!
Re: 2nd Gear Chirp (savedbyzero)
Posted: Tue Jul 29, 2003 11:40 am
by JustinVGT
quote:I would say it's actually good that you're not. But if you want to do it, drop the clutch hard at the top of first into second...CHIRP!Yeah, I know it's not good for it, I was just wondering how it's done.
Posted: Wed Jul 30, 2003 2:53 am
by dmitri
if u slam the clutch down, your wasting time. I shift with my clutch only a quarter of the way down, which is about where it lets go.
Re: 2nd Gear Chirp (dmitri)
Posted: Wed Jul 30, 2003 4:30 am
by slbpsi63
quote:if u slam the clutch down, your wasting time. I shift with my clutch only a quarter of the way down, which is about where it lets go. Good call Thats what I do
Posted: Mon Aug 18, 2003 12:56 am
by Hot Vibe
The problem is tha you are probably letting off of the gas.
Re: 2nd Gear Chirp (Hot Vibe)
Posted: Mon Aug 18, 2003 1:40 am
by dmitri
lol i dont let off the gas when i shift i let go so its not floored but im still pushing it.
Posted: Mon Aug 18, 2003 9:08 am
by MadBill
If you're shifting at or near the red line, you don't actually have to lift off the throttle at all. You can just dip the clutch a bit and slam the next gear on the first burp of the rev limiter. It works fine for me, but I don't plan to make a habit of it. >insert weasel words here about being on your own if anything goes wrong<
Posted: Tue Aug 19, 2003 2:27 am
by Hot Vibe
Keep your right foot on the floor and you will get the chirp. Dont be afraid just practice shifting gears faster. IF the RPM's are high enough you may not even have to push in the clutch. "DRIVE IT LIKE YOU STOLE IT!!!!!".
