manual locks
Posted: Fri Jul 05, 2013 8:33 am
by rockinghammer
Hi Vibe Lounge,
Recently bought a 2003 Vibe - 3rd owner- that's been very well cared for. 168K, clean, rust-free, very smooth-running. I'm pretty pleased with it, especially at $4K! The only glitch I've found is with the manual locks. Driver door will unlock with the key (clockwise) but won't lock with the key. Passenger door will lock (clockwise) but won't turn to unlock. The hatch door lock won't turn either way. To lock/unlock the hatch I have to pop the panel inside and pull/push the rod from the lock to latch. You can imagine how much fun it is crawling over luggage and whatnot via the backseat! I've used some Krown lube in the keyhole to no avail, and frankly, given the overall condition and the ease with which the front locks turn I can't see them being particularly corroded.
This isn't a big problem out here in the country, but I usually want to lock up in the big city. Any suggestions, advice would be much appreciated.
Regards,
Rockinghammer
Re: manual locks
Posted: Fri Jul 05, 2013 9:23 am
by Chiadog
Can't help ya' with the front locks, but i had the same situation with the hatch lock on my 05 base. The lock mechanism was corroded and stuck tight! Had to pull the rear hatch panels off the inside and disassemble/clean/lube the lock mechanism. works great now.
Re: manual locks
Posted: Sat Jul 06, 2013 11:07 am
by rockinghammer
Yeah, thanks Chiadog. I took the panel off and figured out how to get the lock out. The cylinder is totally frozen in the lock. Lube just isn't going to do it. I'm looking for info now on dissolving aluminum corrosion.
Re: manual locks
Posted: Sat Jul 06, 2013 1:17 pm
by Chiadog
Arm and Hammer washing Soda works good on iron and steel, not sure about aluminum. Search Youtube. :)
Re: manual locks
Posted: Sat Jul 06, 2013 8:57 pm
by Rayven01
A couple of tablespoons of cream of tartar in a quart of water is worth a shot. It will clean aluminum discoloration and mild corrosion. Soak it a good long while.
