Dome light help
Posted: Fri Jun 21, 2013 3:45 pm
by harryb
I was changing the LED in my dome light (2006) when the plastic switch fell out of the light. There was also a small spring that fell. I can't figure out how they go back in - something should be holding the switch tight against the light body, but I don't know what. Was there maybe another piece that also fell out?
Harry
Re: Dome light help
Posted: Sat Jun 22, 2013 6:17 pm
by Derf
Do you have any pictures? Can try to compare what you don't have against a complete unit.
Re: Dome light help
Posted: Sun Jun 23, 2013 9:53 am
by harryb
OK - here's the light:
The switch mechanism goes on the far right. And here's the two parts of the switch that fell out:
I've looked and can't find anything else that looks like something that would have fallen out, but it sure seems like something is missing.
Thanks!
Harry
Re: Dome light help
Posted: Sun Jun 23, 2013 5:10 pm
by Derf
Parts reference, but no switch:
http://parts.nalleygmc.com/showAssembly ... evel=14445" onclick="window.open(this.href);return false;
Appears the courtesy light is a fixture, so unable to locate sub parts. I have the moon and tunes courtesy switch arrangement, unable to compare yours against min.
The assembly goes into the headliner, worst case you find the courtesy light assembly on e-bay (just searched, only found bulbs no assemblies) and swap your complete unit.
