Blower Fan
Posted: Tue Jun 11, 2013 11:55 am
by plfx4
My blower fan only run on the 3rd and 4th gear.
Should I replace the resistor or I should consider something else.
Some says that if it's the resistor it will only work on the fourth one...
Help
Thanks
Re: Blower Fan
Posted: Tue Jun 11, 2013 2:50 pm
by SeattleJeremy
Blower motor resistors contain controls that determine air settings, each control on your dash relates to a resistor inside the Blower Motor resistor module.
The fact 1-2 don't work, is enough to say replacing the blower motor resistor module should fix the problem.
