Question about Seafoam?
Posted: Tue Jun 11, 2013 6:44 am
by Vibelo
Hello this is my third post. After reading all the great input about seafoam on this site I proceeded to buy a bottle and follow the instructions. In my case, no smoke ever came out when I did the procedure. Could that be normal? It seems that whoever had this car did all the maintenance required as in only has 89,000 miles. Car runs fine. However, in the mornings when I start it up even before I did the seafoam, there is a small cloud of smoke for a few seconds, this is why I did the seafoam in the first place. Is this smoke at start up a bad sign? Your input is greatly appreciated.
Re: Question about Seafoam?
Posted: Tue Jun 11, 2013 7:02 am
by Rayven01
What color is the "smoke"? If it's white it's not smoke, it's water vapor from the moisture in the exhaust evaporating as it heats up. This is completely normal at start-up. The colder it is outside the longer it will do it. If it's dark gray or black then it's actually smoke from something being burned off.
Posted: Tue Jun 11, 2013 8:37 am
by Vibelo
The smoke is gray
Posted: Tue Jun 11, 2013 8:39 am
by Vulcan05
One possibility is oil leaking past the valve stem seals. Unless it is REALLY bad, it's cheaper to add a little oil than it is to replace the seals.
Posted: Wed Jun 12, 2013 9:44 am
by Vibelo
So it is possible that no smoke came out when I perform the seafoam procedure? Anyone?
Posted: Wed Jun 12, 2013 3:06 pm
by Chiadog
I've done the Seafoam procedure 3 times. Huge amount of smoke each time (different cars). I think it is important to follow all instructions completely. In addition, The can may need to be held upright during the procedure. Is it possible to get a bad can that doesn't discharge the product? Possibly.
Posted: Mon Jul 01, 2013 8:16 pm
by triz
Any reason why your running Seafoam?
Posted: Mon Jul 01, 2013 8:25 pm
by Th17kit
From what I've read on multiple sites (about to use it myself), if you add it to your gas tank you don't get to enjoy the smoking extravaganza, if you add it directly into your engine then it's 4th and New Years all at once.
Posted: Tue Jul 02, 2013 9:08 pm
by triz
http://www.amsoil.com/shop/by-product/o ... e=APFSC-EA
I've never used the stuff before so I cant comment on it. But here is Amsoils version.
Posted: Thu Jul 04, 2013 9:41 pm
by Th17kit
I just used it in a 1996 Accord v6, a single cylinder '08 150cc scooter, and the 09 Vibe by mixing in proper amounts (1oz/gallon gas). I can confirm that none smoked. The 96 and the scooter were noticeably better performers though (scooter was faster, Accord was smoother). Vibe didn't seem to make a difference, probably cause it's been well cared for.
Posted: Fri Jul 05, 2013 7:23 pm
by Chiadog
Vibelo wrote: After reading all the great input about seafoam on this site I proceeded to buy a bottle and follow the instructions. In my case, no smoke ever came out when I did the procedure.
Hey Vibelo,
Did you add the Seafoam to the gas tank, or did you do the "spray it into the induction system" procedure? My 140K 05 base Vibe smoked like a Banshee when I sprayed it! If a Banshee smokes, that is. :lol:
