New Member with Poor Gas Mileage
Posted: Sun Jun 02, 2013 1:19 pm
New member who's already learned a lot just by finding this forum.
I bought a used 2006 Vibe base from a GM dealer a few months ago. Around 95,000 miles now and seems to run good. However, gas mileage is poor, less-than-expected 23 mpg, no matter city or highway, no matter gentle or more aggressive driving.
We replaced air filter, put Techron fuel additive in two times, cleaned MAF sensor, using the excellent instructions we found on this forum. Bought new spark plugs and PCV valve but haven’t put them in yet. Plenty of power and no CEL, so we don’t think O2 sensors or catalytic converter would be the cause.
I searched for reasons for the poor mpg and found a thread about “jack rabbit starts and poor mpg of 19-21†and think mine may have an ECM computer problem. The Vibe was squealing the front tires when we would drive off from a stop. Since they were more worn than the back, I imagine the previous owner had had the same problem for some time. We had the tires rotated so the better ones are on the front.
I looked at the ECM recall threads. Ours is a 89661-02K41. Hard to read those small numbers, but with a mirror, I think mine is 8746, so the chart said it was “good†and not eligible for the replacement under the recall.
I still think the lousy mpg is due to some defect in the computer. Is there any way I can hack the existing computer to fix it to get better mpg? I’ve looked online for used and new replacement ECMs. I’m wary of a used one (from eBay) unless I could get one from an owner who swears he got at least 30 mpg. I’ve also read that swap outs may need programming. Does a dealer have to do it, or can I do it myself? My husband thought of RockAuto as a place that might carry new ECMs. Not sure which ACDelco model to pick there—Vibe is AT, FWD, base w ABS. ACDELCO Part # 19205364 MODULE,Powertrain Control w/ACTIVE BRAKE CONTROL(JL4) or 4-SPD AUTO TRANS(MU4); Base Model. If we have ABS, do we need w/Active brake control? There’s only one choice for the Matrix there: STANDARD MOTOR PRODUCTS Part # EM11375 Reman, which oddly enough is my exact same 89661-02K41, says w/o Traction control.
Can someone advise me on what to do? Has anyone replaced ECM like mine that was not covered in the recall? And where do I complain; maybe there should be an extended recall to cover mine, too.
We like our Vibe, but we would like to get better gas mileage. Thanks.
