2009 Vibe GT wheels on 2004 Vibe Base
Posted: Sat Apr 20, 2013 3:22 pm
by sgary
Ok, so I just got a great deal on a set of 2009 Vibe GT wheels, and I find out that the offset is 5x114.3 on the 09 gt wheels, and my vibe has a 5x100 offset.
I found some wheel adapters that are 1 inch thick, has anyone used these or experienced any issues?
Re: 2009 Vibe GT wheels on 2004 Vibe Base
Posted: Sat Apr 20, 2013 6:52 pm
by trb
Not recommended as the adapters will push out your wheels a full inch, so you will probably hit the fenders with the tires. They would look nice, and I wish I could have put them on my son's 06, I but ended up getting some of the 17" alloy wheels instead since I knew they would fit.
Since you have them, maybe you can try to mock them up, like getting a piece of 1" wood to use as a spacer and see how much farther they stick out than the stock ones.
Posted: Fri May 17, 2013 9:33 pm
by 09Viberator
i believe Konig has some rims that look really similar to the 09/10 GT rims but i will look into it....
Posted: Sat May 18, 2013 11:07 am
by REN69
offset is the distance of the mounting points from the center of the wheel... usually a 1-2 digit positive or negative number like +45, 0(zero) or -15, etc...
you're describing Bolt Pattern when you say 5x114.3 or 5x100. :)
Posted: Wed May 29, 2013 5:34 pm
by sgary
I bit the bullet ordered the wheel adapters, and had a brand new tires installed on the rims, and mounted them up, and here's what it looks like...
Posted: Wed May 29, 2013 5:35 pm
by sgary
Now the speedo is just a hair off, now I need to figure out how to recalibrate it....
Posted: Wed May 29, 2013 5:48 pm
by trb
Looks good from the side. How does it look from the front & rear? Do they stick out much?
Posted: Wed May 29, 2013 6:06 pm
by sgary
I will have to take more pictures and get them up, but no does not really stick out they are within the tops of the wheel wells.
Posted: Sat Jun 01, 2013 9:49 am
by vibenvy
The wheels look great! It's just so weird to see them on a 1st gen Vibe :P!
Posted: Tue Jul 16, 2013 4:17 pm
by sgary
Thanks for the compliment, actually I am used to looking at them now, and the stock rims on my blue vibe don't look normal now.
It is amazing how much better the car handles now too with the performance tires on it, takes corners real well, it feels like a totally different car when driving it.
Posted: Mon Mar 24, 2014 8:05 pm
by salocin
Just curious how the car rides now ?
