starter removal
Posted: Fri Apr 12, 2013 3:34 pm
by lunyty
car would not start today, no click no nothing,,,looks like it needs a starter,good voltage at switch wire at starter,my problem is access to the top starter bolt,,,,would it be easier to remove intake to get to that bolt ,or is there a trick im not seeing ??any help appreciated
Re: starter removal
Posted: Fri Apr 12, 2013 3:46 pm
by keithvibe
no click is usually the battery, did you have the battery load tested?
Re: starter removal
Posted: Fri Apr 12, 2013 5:29 pm
by lunyty
battery was 12.6,,,and when turned the key got 12.6 at the switch wire on the starter ,,,,,,so yes battery 2 months old
Re: starter removal
Posted: Fri Apr 12, 2013 6:04 pm
by JohnO
The starters are not hard to repair yourself. See my message in this thread for info on how to do it:
viewtopic.php?f=17&t=40551&p=479033&hil ... er#p479033" onclick="window.open(this.href);return false;
