help: need factory part numbers for interior pieces
Posted: Sat Jul 26, 2003 2:55 am
by cibomatto
These are the five pieces similar to the pic posted...anyone have the GM part numbers? I recall someone here with that capability Thanks
Re: help: need factory part numbers for interior pieces (cibomatto)
Posted: Wed Jul 30, 2003 6:16 am
by cibomatto
BumpCan anyone verify if these are correct..doesn't seem right to me88970554 instrument panel accessory center trim plate upper (chrome)includes retainer, clip, screw and air outlet88970556 instrument panel accessory center trim plate lower(black/chrome)88970562 instrument panel lower extension trim panel (includes spring)used through production date 10/0288973108 instrument panel lower extension trim panel (includes spring)used through production date 11/0288970561 instrument panel accessory upper trim plate (includesretainter, clip, screw, and air outlet LH
Posted: Wed Jul 30, 2003 9:25 am
I don't have vibe prts list, but there's a Matrix parts list PDF out there and here's a clip from it that shows dash type trim pieces. I don't know how valid the prices are anymore, but might give you a comparison once you price the GM parts, might be better to but them from ToyotaThe complete parts list is available on a link from
http://forums.genvibe.com/zerothread?id=1232,
Re: help: need factory part numbers for interior pieces (joatmon)
Posted: Wed Jul 30, 2003 9:32 am
and one for the armrest pieces
Posted: Wed Jul 30, 2003 9:35 am
by cibomatto
Excellent.... Thanks for the pics.. this will help alot in making sure I get the right pieces for my Vibe
Posted: Wed Jul 30, 2003 10:03 am
You can ping on ragingfish for the GM numbers, he said he had a Vibe parts list
http://forums.genvibe.com/zerothread?id=4566
Posted: Fri Aug 01, 2003 1:37 am
by Psychobroker
Good God those prices are CRAZY! Also, since when do we have a glove box lock?
Posted: Fri Aug 01, 2003 2:16 am
Here are the part numbers you need:Plate, Trim (left air vent and mirror controls) 88970561 $26.11Panel, Upper Center Trim (radio) 88970554 $38.81Panel, Lower Center Trim (shifter) 88970556 $46.25Plate, Switch Mount (Pwr locks and window, Psgr Door) 88970396-7 $29.26The only number I can't locate is the one for the driver door trim piece...my list shows them as interchangeable, but obviously, they're not. I'll keep looking though...
Re: help: need factory part numbers for interior pieces (ragingfish)
Posted: Fri Aug 01, 2003 2:27 am
Those prices are a lot better than the ones in the Matrix parts list. I'd say if you're going to buy them, it would still be worth checking both Toyota and GM for current prices.What the matrix list calls a glove compartment lock is probably just the latch.
Posted: Fri Aug 01, 2003 2:33 am
quote:What the matrix list calls a glove compartment lock is probably just the latch.Vibe part lists shows the same thing, and it is pointing to the latch.I hate oen thing on our car, and that is that GM cars always have part numbers stamped on the back of the part. Ours have numbers, but they don't correlate to our part numbers. It makes finding part numbers absurdly difficult!
