Transmission REMOVAL!!!!
Posted: Sat Apr 06, 2013 7:02 pm
by mango02
2003 Vibe 5 Speed. Need to remove and try to rebuild Gearbox. Need a breakdown on how to remove box from car. Do I need to remove the entire unit or can I just remove the Gearbox???? Schematic would be nice and a little advice. I have the car on jack stands, removed almost all components from car. Yes going install new Clutch kit also.
Re: Transmission REMOVAL!!!!
Posted: Sun Apr 07, 2013 2:48 pm
by thebarber
Remove airbox, battery axles, you can get at all bolts/mounts
Pull tranny
Swap to 6 speed from xrs/GT....forget a rebuild
Posted: Wed Apr 10, 2013 5:14 pm
by mango02
WOW barber you are good! Thanks for your help........
Posted: Wed Apr 10, 2013 7:47 pm
by mac99d
mango02 wrote:WOW barber you are good! Thanks for your help........
lol....... so what kind of stuff are you needing to know this might help. http://wehavescissors.blogspot.com/2009 ... be-or.html" onclick="window.open(this.href);return false;
Posted: Sat Feb 01, 2014 5:08 am
by sailingharry
That link to the clutch replacement document ROCKS. Thanks!
I'm afraid I may doing what the OP indicated -- remove the transmission to repair it. My son's '04 is making very bad signs of the dreaded transmission bearing failure.
Has anyone every opened up a Vibe transmission? Does anyone know WHICH bearing it is? I've replaced a single bearing in a transmission twice before (a 86 Mazda pickup and a 94 Civic hatch), so the work is well within my ability. In the case of the Civic, I knew which bearing it was before I started the job (input shaft bearing), so I actually had the parts on hand when I started -- making it go much faster.
Also, at 120K miles, should we do the clutch? I did the clutch when I did the Civic at 185K -- but the original clutch was still in great shape and really didn't need it.
Any help would be greatly appreciated!
Harry
Posted: Sun Feb 02, 2014 7:13 pm
by thebarber
sailingharry wrote:That link to the clutch replacement document ROCKS. Thanks!
Harry
if you care at all about performance, id get a new clutch and a lightweight flywheel.
for the headache of opening the transmission, you're still better off to find a c60 6speed and just swap it in
