how do you shorten 2009 auto shifter
Posted: Sat Mar 30, 2013 1:41 pm
by jmkcc
I am trying to shorten the shifter for 2009 with automatic, gated shifter. I sawed off about an inch, but I'd like to go shorter. I started to thread 8mm * 1.25 with a die, but as soon as it hit the end of the production threads, the whole rod started to turn. I figured I could just unscrew the whole rod and bring it in to place on a vice, but while it turns, it does not move in or out. Anyone know how the shifter is attached? I did not want to go ripping everything apart without having an idea of what is involved. It's a royal pain, but I can not use the cupholders as I always hit the shift knob. Even when reaching for the radio, I knock it our of gear.
Re: how do you shorten 2009 auto shifter
Posted: Sun Mar 31, 2013 8:59 am
by beemerphile1
I wish I had an answer but I don't.
That shifter sticking up in the way has always been an annoyance for me also. I really don't understand why modern automatics even have a shifter. Back in the sixties some cars had push button electric shift, you would think they had perfected it by now. That lever and the console beneath it take up a lot of real estate unnecessarily.
Let us know the solution when you figure it out, please.
Posted: Sun Mar 31, 2013 12:25 pm
by ColonelPanic
Dodge has been workin' on it...
If shifting will be electronically controlled anyway, bring it.
Posted: Mon Apr 01, 2013 4:55 pm
by 09vGT
http://reviews.cnet.com/2300-31347_7-10011873-8.html" onclick="window.open(this.href);return false;
So has Lincoln.
