What is it?
Posted: Mon Mar 25, 2013 10:46 am
What is this and why is it going "Tick, tick, thick,tick tick,thck"?
https://forums.genvibe.com/phpBB3/
I'm pretty sure that's the VSV (Vacuum Switching Valve)... had to relocate it when installing a cold air intake and know it makes a ticking sound as you indicated.LedFootin wrote:What is this and why is it going "Tick, tick, thick,tick tick,thck"?
Yes, I had to relocate it when I installed the SRI but, is it suposed to be that loud or do I need to replase the screwy thing?NSimkins wrote:I'm pretty sure that's the VSV (Vacuum Switching Valve)... had to relocate it when installing a cold air intake and know it makes a ticking sound as you indicated.
Mine's loud as well. I might very well be wrong, but I believe it's part of the system that takes evaporated gasoline from the gas tank and spits it into the intake manifold for emissions. The vapors are stored in a canister at the back end of the car, then when it's warmed up, sent to the front. That may be why it's so loud, but I can't be too sure if it's SUPPOSED to be.LedFootin wrote: Yes, I had to relocate it when I installed the SRI but, is it suposed to be that loud or do I need to replase the screwy thing?
