Welp...More wheel bearings
Posted: Mon Mar 25, 2013 5:08 am
by clownshoes
Ok,
So, more wheel bearing noise. Don't know where it's coming from. Front I think.
Back to the garage tomorow. Hopefully its the same one that I had replaced and it'll get done under warranty. Most likely not. We'll find out what else is messed up.
This suspension is taking a beating for only highway driving.
I doubt I can get pics. It'll try though.
Ooops... can mods move this to the suspension forum.
Re: Welp...More wheel bearings
Posted: Mon Mar 25, 2013 4:38 pm
by liftoff
probably just another wheel bearing.. I'm in Kingston and this winter sure did take a beating on my vibe. I'm getting my wheel bearing (front) replaced this week. Has a ton of play but only recently started making noise. Good luck with the fix.
Posted: Tue Mar 26, 2013 10:43 am
by clownshoes
Welp....looks like its the front wheel bearing as well. It was making noise before the winter, but limped it through.
$452 smackeroonies later....Pick it up this afternoon.
Glad it wasn't the rear. I'm not in the mood to pay over $700 again.
Posted: Tue Mar 26, 2013 1:48 pm
by SeattleJeremy
I have a failing rear wheel bearing. So I'm curious, could you provide a break down of the costs that went to make up these numbers?
Posted: Wed Mar 27, 2013 7:49 pm
by lannvouivre
SeattleJeremy wrote:I have a failing rear wheel bearing. So I'm curious, could you provide a break down of the costs that went to make up these numbers?
I assume mostly labor, I don't think the bearings themselves cost much unless you buy the hub assembly, which costs something like twice as much. I think average labor for an automechanic is $100-$130 per hour.
Posted: Thu Mar 28, 2013 5:30 am
by clownshoes
Ok, I had my rear wheel bearing replaced in January of 2012.
I had it replaced with an AC Delco part. The bearing included the ABS sensor for around $450 bucks. The labour was about $300.
This is at least a $700 repair bill.
So everyone knows. The rear wheel bearings are the EXPENSIVE ones to replace. The front are the CHEAPER ones to replace.
Posted: Thu Mar 28, 2013 6:23 am
by Rayven01
clownshoes wrote:The bearing included the ABS sensor for around $450 bucks.
Wow, that's some serious markup on that bearing! It lists for $320, and can be gotten from online dealers for $200.
Posted: Thu Mar 28, 2013 11:56 am
by SeattleJeremy
Oh, very interesting. The rear bearings on this car are different than the other cars I've seen. It's only sold as a "Wheel Bearing & Hub Assembly" and the bearing isn't sold separably.
It looks like the rear bearings on the Vibe have the same type of configuration as the ones on this Caravan.
http://www.youtube.com/watch?v=VRDrZoIGCEE" onclick="window.open(this.href);return false;
Posted: Mon Apr 01, 2013 5:14 am
by clownshoes
The rear bearings are a hub assembly type. You cannot "just replace the bearing" on this kind of set up. It's an assembly.
