Taking Vibe GT to 1/4 mile drag strip tonight!!
Posted: Thu Jul 24, 2003 10:58 pm
by QUIKAG
Any advice on launching technique? I'm figuring a 4-5k mild clutch slip going full throttle off the line, then powershifting second gear to help keep the car in lift. Anything else??
Re: Taking Vibe GT to 1/4 mile drag strip tonight!! (QUIKAG)
Posted: Fri Jul 25, 2003 12:49 am
by x2nddavex
i don't have any advice, but when you get back, post your time, i'm curious what our gt's are capable of. thanks
Posted: Sat Jul 26, 2003 5:57 am
by satur9
let me know if you need a helmet what did they check for tech inspection etc. basically can you just go and make runs or what?
Posted: Sat Jul 26, 2003 9:25 am
by MadBill
Quote End quoteYes: Take the plates off, just in case word gets back to your dealer or insurance agent! (And if anything untoward should happen, don't have the dealer tow it in from the track... )Oh, and try not to make any unflattering performance comparisons with your Vette!
Re: Taking Vibe GT to 1/4 mile drag strip tonight!! (MadBill)
Posted: Sun Jul 27, 2003 11:09 pm
by Chris
Make as many passes as you can. It takes a while to learn your car and figure out what's best... little clutch slip, little wheelspin, where to stage.I've never dragged a car before however I did find that when dragging my bike, I'd skip the burnout and stage just a little off centre so as not to put my wheel on the rubber left by the cars cuz my best launch was a bit of wheelspin otherwise a bog would kill your et.So, my suggestion would be to stage off the rubber, get some wheelspin and go... too much hook-up and you'll bog and get a bad timeHave a great time and good luck!
Re: Taking Vibe GT to 1/4 mile drag strip tonight!! (satur9)
Posted: Mon Aug 04, 2003 1:20 pm
by Vibe GTR
Here in central texas, $5 to get in, $10 to run as many times as you want on friday test and tune night. Helmet only if you do 13.99 or better. brakes good, no leaks, no siucide doors, and seatbelts must work. oh yea sign waiver( track not responable is you kill yourself) Launch around 5-5500 rpms keep in lift(tricky at first). best time so far 16.2@ 85mph. People will laugh at first until they see and hear lift. the only mods done TRD airfilter and royal purple oil. Its FUN , what a RUSH. GOODLUCK
Posted: Mon Aug 04, 2003 11:00 pm
by NovaResource
quote:Taking Vibe GT to 1/4 mile drag strip tonight!! (QUIKAG)So what were the times? This was a week and a half ago.
Re: Taking Vibe GT to 1/4 mile drag strip tonight!! (x2nddavex)
Posted: Wed Aug 13, 2003 1:37 am
by CaCathy13
15.3 1/4 mile time hereI got underdrive pullies on last week...going to be racing in Albany, NY next week. We'll see if there is any difference.
Re: Taking Vibe GT to 1/4 mile drag strip tonight!! (CaCathy13)
Posted: Wed Aug 13, 2003 8:10 am
by dmitri
does your car idle any different? how does it run? do any of the accessories or your system (if you have one) act differently?
Re: Taking Vibe GT to 1/4 mile drag strip tonight!! (dmitri)
Posted: Wed Aug 13, 2003 12:47 pm
by Pablo1669
quote:does your car idle any different? how does it run? do any of the accessories or your system (if you have one) act differently?I have the underdrive pulleys also. nah, it runs fine, no real differences in the accessories or anything like that. I do like the improvement in speed, you'll really feel it in lift, especially 3rd gear... what a rush.
Re: Taking Vibe GT to 1/4 mile drag strip tonight!! (NovaResource)
Posted: Mon Sep 08, 2003 8:12 pm
by QUIKAG
quote:Taking Vibe GT to 1/4 mile drag strip tonight!! (QUIKAG)So what were the times? This was a week and a half ago.Sorry guys/gals, I forgot I made this post in the forum.I made a few passes, the track was HORRIBLE and the weather was very humid and near 100 degrees. Also, I think my 17 inch wheel/tire package was hurting me off the line pretty bad. Even with a 4000rpm clutch DUMP, it was bogging off the line, and then the crappy track was allowing some spinning through the top of first into second. Basically, it was pretty ugly.On both passes I ran a 16.2 at 89mph. With better track and weather conditions, I can easily get mid 15's at 91mph or so.Either way, it's definitely not as easy to get down the track as my other car.
