'03 Base new front brakes - Life is good!
Posted: Mon Mar 11, 2013 5:14 am
Just replaced the front brakes on my '03 Base (122k miles - 2nd set of pads/rotors). After having an issue with some el-cheapo Chinese rotors that I installed ~50k miles ago (a chunk of the rotor surface actually de-laminated
), I put on some quality Napa Ultra-Premium rotors and some AdaptiveOne ceramic pads over the weekend. My braking has never been better!!! I about ate the steering wheel once I broke the pads in
I have learned a lot about rotors and pads over the last few years having dealing with an issue on my better half's Grand Prix and have found it is not worth saving a few bucks on inferior brake parts.
I had to do the "quick fix" above to get my Viberator back on the road (busy with work, not much free time) but my near future plan is to:
- replace the calipers
- replace the OEM rubber brake lines with stainless steel ones (for even better brake response)
- replace the rear drums, wheel cylinders, hardware, and shoes
- bleed out the old fluid with fresh
Links to the rotors and pads I used:
Rotors - http://www.napaonline.com/Catalog/Catal ... 0129748433
Pads - http://www.napaonline.com/Catalog/Catal ... 0319622896
