2010 Vibe Auto Headlight mod - partial failure
Posted: Sat Mar 09, 2013 12:50 pm
Hi,
I have found the auto light annoying and I believe some have the same feeling.
Then I tried to disable it and I saw some pop out the light sensor, and thus disabled the auto light but the Daytine Running Light is still working.
Today I did that. It was pretty simple, just use a flat head screw driver (if you have a plastics one, use it - less chance to scratch the hard plastics) and po it from left and right side.
Then you can unplug the wire hardness from the sensor.
From those 2003-08 version, report said the auto light is gone but DRL is still there.
I found on my car that the auto light is gone, however so as the DRL - it won't light up! I like the DRL since it is a safety function. Will try to find out the schematic to see if there is any wiring that I can bring this back.
Be careful, when the wire hardness is loosen, it will drop down under the panel and very hard to get it out again. The place is just too narrow for any too. I tried an hour and still can't get it out!!!!
Hope this helps anyone who want to do the auto light mod.
Tony
Tony
