02 Sensor replacement. Heated vs. non-heated
Posted: Wed Mar 06, 2013 12:03 pm
Hello all.
The CEL light on my 2007 Vibe turned on about a week ago. My car is a base-model FWD with about 80,000 miles on it. I had the computer scanned at O'Reillys. It was a P1071 "Running Lean" Bank 1 code. I cleaned the MAF sensor and checked for vacuum leaks. I reset the CEL light when I cleaned the MAF by disconnecting the battery. 85 miles later, the CEL light came back on. I took it to the local mechanic and he said it needs a new upstream o2 sensor (based on their diagnosis). They wanted $245 for the sensor. I thought that was a bit STEEP! The guy said he called 3 different places as he was surprised at the cost. I went ahead and found a replacement sensor on my own (see link below).
http://shop.advanceautoparts.com/webapp ... fragment-2" onclick="window.open(this.href);return false;
Anyways, my question is, is an Air Fuel Sensor the same thing as an o2 sensor? Also, the mechanic said my Vibe requires a heated o2 sensor, which the Denso product (see link above) is heated. However, when I researched that same part (part # 234-9052) on some other websites, those websites said it is non-heated (see link below). Which web-site is right here? Is the part heated or not?
This link says it is non-heated:
http://www.autopartswarehouse.com/sku/D ... 49052.html" onclick="window.open(this.href);return false;
Also, the part in the second link says it is a 2-wire and the first link says 4-wire. Do I trust Advanced Autopart's website over the second link?
Anyways, I am not super well-versed with fixing cars, so any insight would help. If you all could provide DETAILED explanations to my questions, that would really help. I went ahead and ordered the Denso "heated" Air Fuel Sensor from advanced autoparts, because it was $100 cheaper than what the mechanic quoted. Will this part replace the upstream o2 sensor on my 07 Vibe? I want to make sure I get this right.
In summary, my questions are:
1. Is an Air Fuel Sensor the same thing as an 02 sensor?
2. Is the part heated or non-heated? How do I know? Will the package say when I pick up the part? (Denso's page doesn't have the specs that I could find)
3. Will this part replace the upstream 02 sensor on my 2007 Vibe?
Thanks in advance everyone. It has been a while since I've been on the site, my Vibe has been running well.
