1zz bearing roll-in?
Posted: Thu Feb 28, 2013 6:12 pm
Hi all, I've got a question that's perhaps rather stupid, but I'm going to go ahead with it anyway. I just recently took over my sisters '04 vibe with a blown clutch and 5 speed manual. I replaced the clutch and swapped in a much younger C60 6 speed at the same time (new rear seal as well). The car has about 310,000 miles on it, but very easy going miles (mostly highway and no hard work). You wouldn't know it had nearly that many miles, except for lacking a bit of its new original power. My next task is to fix up the oil drain plug; at some point it seems her mechanic cross threaded it and every time I undo it it's a pain to get in/out and I'm always worried how long it'll last. My question: on old farm equipment it's common to "tighten up" an engine between proper rebuilds by dropping the pan and rolling in new main & rod bearings with the engine still in the car. Typically we'll take the head to be checked over by a machine shop, lightly hone the block and put new rings on. Is it a stupid idea to think of doing this on my vibe to prolong the life a few more years? Any thoughts are very much appreciated.
