Have some pesky oxidation? You dont have to buy new lenses!!
Posted: Thu Feb 28, 2013 12:58 pm
As we all can guess, the desert sun in AZ destroys plastic an rubber parts. Luckily, there are cheap and effective methods for refinishing oxidized headlight lenses. The method i will show you is used in most body shops to remove the foggy, yellow, nastyness that is robbing you of your viewing distance and safety. The further you can see, the faster you can drive......safely >:D
THINGS TO PROCURE:
2200 grit WET sand paper
a rubbing compound (the coarser grit will be great followed by an optional finer grit)
1 brillo pad/microfiber cloth for applying rubbing compound
1 clean rag
1 rag/spray bottle to wet lenses
water
(can get most items at Autozone or O'rielys auto parts stores and its fairly inexpensive)
STEP 1:
Wet lens with the water.
STEP 2:
sand the entire lens with the sandpaper (be careful around the edges so you don't take the finish off of your paint)
*Make sure that the lens stays wet as your sanding*
Periodically check the lens by rubbing it with your fingers. It should feel very smooth and a little sticky to the touch without any nicks or pits
nicks and pits can be worked out. Be patient
STEP 3:
Once the lens is smooth, apply rubbing compound (its like waxing a car. follow directions on the rubbing compound)
rub the compound in by using small circles and be sure to get the entire lens.
STEP 4:
Wipe off the excess compound.
you dont have to, but you can go over the lenses again with a finer grit rubbing compound for an even better finish.
STEP 5:
Post your success on genvibe!
THINGS TO PROCURE:
1 clean rag
water
STEP 1:
STEP 2:
STEP 3:
STEP 4:
STEP 5:
