2003 vibe gt thermostat issues
Posted: Wed Feb 27, 2013 10:14 am
by metso5
hi everybody
i always go on this site to leech valuable info on my vibe but for once i can post some info on to others,,here goes
i ould start my car in the cold mornings to warm up--it did after 10 minutes---right up to normal operating temps....then as i would drive to work the temp gauce would drop faster than i could read!!!in a matter of thirty seconds my temp gauge would read 50--(removed)!!!anyways i brought my car to whitby toyota(cause the local gm dealership is brutal!!)and after a quick repair i had a new thermostat and my car was perfect again----my old one was stuck open!!!!!its better than stuck closed i guess cause then my vibe would have over heated and bye bye motor--first issue ive had with my car affter 150 000km so im not compaining--it was just a bit mind boggling
Re: 2003 vibe gt thermostat issues
Posted: Sun Mar 10, 2013 2:54 pm
by Flip-Side
You were smart to use a toyota dealer thermastat. The 2z engine has issues with cheap ones like murray or duralast. They die faster than fast, and the oem one is the only one I would ever use on this car.
