New battery from advance auto - are you smarter than...
Posted: Fri Feb 08, 2013 3:40 pm
by Chiadog
Just had a new AutoCraft Silver 26R series (575CCA) battery installed at Advance Auto, Cost $91.73. I decided to test this new battery by turning on the low beams with the engine and ignition off to see how long it would take to drain the battery to 50% or so.
I ended up running the battery down to 37% capacity. Any educated guesses as to how long this took? Low beams only, no fog lights or interior lights, etc.
12 Volt battery % charge chart:
http://www.mmbalmainauto.com.au/PDF/Sta ... teries.pdf" onclick="window.open(this.href);return false;
Chiadog
Re: New battery from advance auto - are you smarter than...
Posted: Fri Feb 08, 2013 5:15 pm
Hmmmm ...... Somewhere between 60 & 90 min? Just a wild guess
Posted: Fri Feb 08, 2013 5:21 pm
by ColonelPanic
Fun science experiment, but not one I would do on a brand new battery I just spent $91.73 on.
Posted: Fri Feb 08, 2013 6:33 pm
by beemerphile1
I could estimate the AH capacity of the battery and estimate the amp draw of the lights to come up with a WAG but I won't. Just thought I would point out that a new battery does not have full capacity until it has been cycled several times.
I like to use this chart;
Posted: Fri Feb 08, 2013 8:07 pm
by Chiadog
tpollauf wrote:Hmmmm ...... Somewhere between 60 & 90 min? Just a wild guess
WE HAVE A WINNER HERE!!!!!
ACTUAL TIME FROM 100% TO 37% CHARGE: 80 MINUTES. Ding-Ding-Ding-Ding-Ding ..... that's the best i can do!
chiadog
Posted: Fri Feb 08, 2013 8:09 pm
by Chiadog
ColonelPanic wrote:Fun science experiment, but not one I would do on a brand new battery I just spent $91.73 on.
Come On Colonel! Take a walk on the wild side!
chiadog
Posted: Fri Feb 08, 2013 9:42 pm
by jake75
beemerphile1 wrote:I could estimate the AH capacity of the battery and estimate the amp draw of the lights to come up with a WAG but I won't. Just thought I would point out that a new battery does not have full capacity until it has been cycled several times.
Does a battery ever get "cycled" if the alternator keeps it "topped off" so to speak?
Posted: Mon Feb 25, 2013 5:53 pm
by 09SnowyVibe
Keeping in mind, anytime you discharge a battery enough to dim the lights, you just lost 10-20 percent of its remaining life. Its worse when its freezing outside. If you must discharge a battery to that extent, consider a deep cycle battery.
I found when I put a trickle charger on my cars that sit in the winter, the batteries last alot longer.
Posted: Mon Feb 25, 2013 8:00 pm
by jake75
09SnowyVibe wrote:Keeping in mind, anytime you discharge a battery enough to dim the lights, you just lost 10-20 percent of its remaining life. Its worse when its freezing outside. If you must discharge a battery to that extent, consider a deep cycle battery.
So that's my problem - Ive drained my personal battery enough to dim my lights many times in my 70 years on this earth. I should have zero remaining life! And often I think I do have zero remaining life - or at least some parts of me are in that condition.
