Fixed.
Posted: Sat Feb 02, 2013 12:43 pm
by AustinG
Edit: Problem Solved. Thanks
Re: Engine Ticking After Warm up
Posted: Sat Feb 02, 2013 4:09 pm
by Chiadog
Wouldn't hurt to have a mechanic listen to it! You did check the oil, right?
chiadog
Posted: Sat Feb 02, 2013 7:00 pm
by JohnO
These engines have solid lifters instead of hydraulic. Therefore there is always just a little looseness in the valve train that causes the noise. See:
http://en.wikipedia.org/wiki/Hydraulic_tappet" onclick="window.open(this.href);return false;
The noise is normally louder at startup or when the weather is cold. In cold weather it may take 10 miles for the engine to fully warm.
