Metra stereo install kit 2003-2008 Vibe/Matrix
Posted: Tue Jan 22, 2013 1:04 pm
by trb
I have all of the left over parts from a Metra install kit # 99-8205. The
only part we used was the double DIN faceplate trim piece, so if you are installing a single DIN radio, it has everything you need. We reused the stock metal mounts from the original radio and it worked out well.
http://www.metraonline.com/part/99-8205" onclick="window.open(this.href);return false;
If you are interested and plan to use it, LMK and I can send it out to you.
Re: Metra stereo install kit 2003-2008 Vibe/Matrix
Posted: Thu Jan 24, 2013 3:04 pm
by Chiadog
Hi TRB,
I don't understand double vs single din, but I intend to install a cheap Panasonic car stereo with front mp3 input this Spring. I have a base 05 vibe auto. Do I need this kit to do my install? Thanks for the info and the generous offer!
chiadog
Posted: Thu Jan 24, 2013 8:35 pm
by trb
The stock radio is about a double DIN size. Many of the cheaper replacement radios are only 1/2 as tall, thus they are single DIN size. Most of the older cars had single DIN radios too. In order to fit a single DIN radio in a Vibe you do need the kit.
Here is a single DIN radio in a Vibe with space for the additional tray on the bottom.
Pic of a kit set up for a single DIN radio:
If you want it, just PM me your address and I'll send it.
Posted: Thu Jan 24, 2013 9:10 pm
by Chiadog
Thanks TRB!
PM has been sent.
Chiadog
Posted: Fri Feb 01, 2013 9:24 pm
by Chiadog
Hey TRB,
I just received the Vibe Metra stereo install kit and I will be using it to replace my "light-less and non-mp3" factory radio this Spring! I think your act of kindness should put you in the poll position for Member of the Year!
Thank you very much.
Chiadog
