Blown cig. fuse, diagram needed.
Posted: Thu Jan 17, 2013 4:21 pm
by Chiadog
The cigarette lighter fuse (15A) blew yesterday in my 2005 base vibe. It blew again immediately upon replacing it. Appears to be a direct short in the circuit. I think I am only missing power to the lighter and the radio, everything else seems to be working-including radio illumination. Does anyone have a wiring diagram of this circuit?
I struck out with my local library and it is not shown in the Haynes manual.
Thanks,
chiadog :(
Re: Blown cig. fuse, diagram needed.
Posted: Fri Jan 18, 2013 6:50 pm
by bluneon
make sure there isn't anything left inside the cig lighter receptacle that could cause the short.
Posted: Tue Jan 22, 2013 11:19 am
by Chiadog
Diagram? or can someone tell me exactly what circuits/accessories the CIG fuse powers? No rush - too cold to work in unheated garage, 3deg. F. right now!
chiadog
Posted: Fri Feb 01, 2013 9:51 pm
by Chiadog
Same as post above - Diagram? Except it is no longer 3 F degrees, Right now it is 4.1 F degrees ....Yeah!
chiadog
Posted: Sun Feb 10, 2013 11:11 am
The wiring diagrams that are available are really poor at answering the top down question of what is powered by a specific fuse. They do better with questions from the bottom up, such as what fuses are involved in powering the X device.
The CIG fuse powers the radio and the Cig power outlet. It might power something else, but I don't know what that might be.
Power goes from battery through CIG fuse through ignition switch to radio and outlet. Unlikely that the radio or ignition switch or wiring is shorted out, all of a sudden without you doing anything that might cause such a thing to happen.
The cig lighter sockets in Vibes, on the other hand, have a history of shorting out. replace or disconnect yours, see if that removes the short.
Posted: Sun Feb 10, 2013 2:20 pm
by Chiadog
Thanks Joatman!
It's still too nasty outside for to mess with it. Do you know if I have to tear into the dash to simply disconnect/cut the cigarette lighter wire?
chiadog
Posted: Mon Apr 15, 2013 12:28 pm
by strangerxp
Cigar vibe 05.pdf
(49.89 KiB) Downloaded 456 times
Hello, see the attachment
Posted: Mon Apr 15, 2013 8:00 pm
by Chiadog
Thanks Strangerxp,
I was still looking for this! Definitely more complex than I thought. Do you know what the P/POINT relay is?
Thanks again,
chiadog
Posted: Tue Apr 16, 2013 5:34 am
interesting that the diagram doesn't show the CIG fuse powering the radio
P/POINT is the power outlet in the console between the seats. that outlet isn't there by default in 05-08 vibes, but the relay and wiring is, which is why its easy to add a 12V outlet there. (http://forums.genvibe.com/zerothread?id=13711" onclick="window.open(this.href);return false; ) The P/POINT relay is above the glove box. ( http://forums.genvibe.com/zerothread?id=6403" onclick="window.open(this.href);return false; )
Posted: Tue Apr 16, 2013 7:26 pm
by Chiadog
Thanks Joatmon!
Posted: Wed Apr 17, 2013 1:12 pm
by strangerxp
Joatmon I saw your other post, and are great, relay bypass it's a great idea.
