				CEL Blinking 201k miles
				Posted: Wed Jan 09, 2013 10:21 am
				by msmyer
				201,000 miles later, took my Vibe in for the first (seroius) time in 10 1/2 years (since I bought it brand new)  The CEL is blinking with a rough idle and sluggish ride over 40 mph.  The CEL is throwing several codes of P0301 Cylinder 3 Misfire Detected.  Changed the spark plugs and it is still throwing the code.  Took in to the mechanic 8 am this morning, wish me luck...
				Re: CEL Blinking 201k miles
				Posted: Wed Jan 09, 2013 10:37 am
				good luck. Hope its an easy and low cost fix
				Posted: Wed Jan 09, 2013 11:40 am
				by sideshowalan
				Hopefully it's just a bad ignition coil.  Not too expensive and it's within your abilities if you can do the plugs.
If your mechanic is stumped, you can test it by switching the #3 coil w/ another one and see if the problem code switches to the other cylinder.
				Posted: Wed Jan 09, 2013 1:10 pm
				by msmyer
				sideshowalan wrote:Hopefully it's just a bad ignition coil.  Not too expensive and it's within your abilities if you can do the plugs.
Yep...Bad ignition coil.  What's a reasonable price for parts/labor?
				Posted: Wed Jan 09, 2013 2:32 pm
				by SeattleJeremy
				Rock Auto has the coils available for less than $50 (each) + shipping.
http://www.rockauto.com" onclick="window.open(this.href);return false;
Buying them locally should be around $100 or less.
It should only cost one our of labor to fix.
				Posted: Wed Jan 09, 2013 3:33 pm
				msmyer wrote:201,000 miles later, took my Vibe in for the first (seroius) time in 10 1/2 years (since I bought it brand new)
Man that is one reliable track record there
   Glad I got myself a Vibe
    Also glad it was nothing major and easy to fix.  You certainly got your money's worth out of this car.  Keep it going for another 201K
				Posted: Thu Jan 10, 2013 6:59 am
				There's been very few reports here of those coils failing.
Get it back and fixed yet?
				Posted: Thu Jan 10, 2013 2:28 pm
				by msmyer
				joatmon wrote:There's been very few reports here of those coils failing.
Yep...It was the #3 ignition coil.
Back and fixed. Runs like new...
It was $256 total, with shop fees and tax.
				Posted: Fri Jan 11, 2013 6:39 am
  Should be good for another decade
				Posted: Fri Jan 11, 2013 9:27 am
				by msmyer
70k miles - New Computer covered under powertrain warranty
120k miles - CO2 sensor
150k miles - New starter
Tires and 2 sets of brakes...
Not bad for 10 years and 7 months (May 2002)
Not bad? : )
				Posted: Sat Jan 12, 2013 3:10 pm
				by vibenvy
				msmyer wrote:70k miles - New Computer covered under powertrain warranty
Not bad? : )
Not bad at all! As tpollauf said, makes me really glad I decided to get a Vibe
