Remote FOB compatibility
Posted: Wed Jan 09, 2013 9:24 am
by frankiemenz
Hi has anyone tried to program an older vibe remote to a newer generation vibe, ie a 2008 remote to a 2010 vibe? The 2010's remote and key combo tends to be a bit bulky and can stab your leg and cause discomfort at times. I am aware of the FCC #'s being different, just wondered if any options were available, then I could have a normal key cut and carry the remote and key like the older vibes, mine doesn't have an immobilizer, I know that will be the next topic for discussion lol.
Re: Remote FOB compatibility
Posted: Wed Jan 09, 2013 12:04 pm
by trb
Someone on here had a regular key cut and removed the key from one of the new fobs, basically creating the same thing, a separate key and fob. That is probably the easiest solution.
Posted: Thu Jan 10, 2013 4:36 am
by beemerphile1
I use a regular steel key and use the fob that came with my remote start. You could cut the factory key and use a steel key like mentioned above.
Posted: Tue Mar 19, 2013 7:35 am
by frankiemenz
Thanks for the suggestions on the key, I tried going to a local Home Depot to get a key cut. The guy insists he didn't have a key to match it. Do you remember where you got your steel key(s) made?? I am going to try that route
Posted: Tue Mar 19, 2013 2:56 pm
by trb
You might want to try a real locksmith instead of just anybody at the big box store. It is just a basic Toyota key. My locksmith cut me an extra before i ordered another key with the fob on ebay. The bare key only cost me $1.
Posted: Wed Mar 20, 2013 3:45 am
by beemerphile1
I have never had any luck on keys from big box stores, they usually never work even if they have the blank.
Go to a local hardware store or locksmith.
Posted: Wed Mar 20, 2013 9:58 am
by frankiemenz
Thanks for the replies, I will go to a seasoned locksmith and get some keys made. I know sometimes anything other than a direct replacement type item puts the box stores into a tailspin lol.
