loose cooling fan
Posted: Sat Jan 05, 2013 4:34 pm
by o2ej
the 2006 vibe has a loose fan. If I go OEM, it looks as if the entire shroud assy. is the solution for replacement. or aftermarket? Can an aftermarket fan/motor assy. easily fit without replacing the shroud assy? or is it easier to replace the entire shroud/fan assy? It looks as if the pricing is close to the same.
Thoughts?
Re: loose cooling fan
Posted: Wed Feb 13, 2013 4:22 pm
by Chiadog
JUNK YARD! Usually my answer for replacing parts that generally outlive the car and are easy to replace.
chiadog
