Newbie help on codes
Posted: Fri Dec 07, 2012 4:03 am
I ordered a code reader on line and it came up with P0420 and P0442. After doing research online I see P0442 is a leak. Could this be causing the P0420 code, which apparently means a new cat?
I'd probably have to take my car to a shop to do this kind of work, so should I get them to check for the leak first and see if that corrects the problem before replacing the cat?
I have a 2004 base Vibe with 211,000 miles on it. It's been a great car, and I've never changed the cat or oxygen sensor (if it ain't broke don't fix it methodology).
Thanks for any help
Thanks for any help
