P235 45 17 on stock 09 alloy 7" rims
Posted: Tue Dec 04, 2012 3:08 am
by marq
Just wanting to confirm that somebody has stuffed this larger tire on the stock 17x7 rim (2.4l) without issue.
Recommended rim size for this tire is a little wider but I found a new set of tires a guy bought and wants to sell and will save me $200. Plus I need new tires anyway.
Re: P235 45 17 on stock 09 alloy 7" rims
Posted: Tue Dec 04, 2012 8:30 am
by trb
I have 235/40/18s on my 2010 GT 18x7 wheels with no real issues at all. I do get a bit of rubbing when backing down the driveway with the wheel turned, but the stock size tires rubbed also so I think it is a fault of improperly refastened fender liners (by the prior owner) more than the tire size. I just ran the two sizes on the Miata tire size calculator, and the 235/45/17 is almost exactly the same size as my 235/40/18 tires, only .1 inch difference in diameter smaller.
http://www.miata.net/garage/tirecalc.html" onclick="window.open(this.href);return false;
Also, on Discount Tire, they show the 235/45/17 as an optional tire size for your car.
Posted: Mon Feb 11, 2013 10:19 am
by Kincaid
I am running 225/50-17 on stock rims with Tein H-Tech springs. I also get rubbing on the inner fender well when backing up, once and a while when pulling forward with people in the car. When the all four of the family are in the car the think looks like it is on S-Techs.
Posted: Mon Feb 11, 2013 7:29 pm
by thebarber
Kincaid wrote:I am running 225/50-17 on stock rims with Tein H-Tech springs. I also get rubbing on the inner fender well when backing up, once and a while when pulling forward with people in the car. When the all four of the family are in the car the think looks like it is on S-Techs.
1. your tires are too tall
2. the rubbing is going to be dependent on your wheels' offset..
235 is technically too wide for a 7" rim
i would stick to a 225
