09 Monsoon Sub Upgrade & Other info
Posted: Mon Dec 03, 2012 2:04 pm
Guys,
Made the plunge & Decided to swap out the factory sub with a 12" Infinity Reference I had laying around.. Enclosure custom built from Fiberglass & a foam mold former. Took quite a wihile but I am really pleased with the results. Couple things to mention that I discovered as being in conflict with some of the info I have read on the Monsoon Speakers
1. The Speakers in the system are not 2 Ohm The front doors have the tweeter & midrange wired in Parallel. I just metered the tweeter & it measured a DC resistance of 3.54 ohms....just aboout the standard for any 4 ohm driver. The tweeter also has a small capicitor wired in series with the positive terminal to handle the high pass. It should be no problem to replace these tweeters with just about any other 4ohm tweeter. I can understand how people may assume they are 2 ohm, because if you metered at the amp it would show a lower resistance, but Nope....Drivers are 4 Ohm.
2. Sub swap. Started with some 1" blue foam cut n fit into the cavity. This gave me all the clearances I needed & provided some additional sound baffling along the rear if the enclosure. I then began layup of the glass usine EPOXY RESIN from US Composites... Normal Poly resin will melt the foam almost immediatly... I ended up with a voulme of about 1.3sq ft & finished it off by stuffing it full of poly pillow stuffing after a couple coats of runbberized undercoating on the inside walls. It is a very dead & damped sounding enclosure with no boomy resonant peaks.. Very accurate sound yet still plays very low. I have it running off of a 250w Kicker amp using high level inputs directly from the factory sub. Of all the aftermarket systems I have installed over the years, I can honestly say the output & quality is right up there with this setup. I believe SPL is almost 120 db in car. Almost finished with a custom grill cover using the factore ring from the monsoon sub.
Next Step to swap out these tweeters with some vifa ring radiators........
