Vibe Computers
Posted: Tue Nov 27, 2012 9:53 am
by blankmonkey
I want to get some extra computers for disaster planning.
How many Computers does the Vibe have? Where are they?
Re: Vibe Computers
Posted: Tue Nov 27, 2012 11:22 am
by SeattleJeremy
Planning for Jericho?
Main ECU computer is behind the glove box.
When shopping for a ECU, make sure it's compatible with your car. There are lots of ECU's out there, and only the one that matches your car will fully work.
Year: 03-04 (drive by cable), 05-08 (drive by wire), 09-10 (new style)
Transmissions: Manual, Automatic
Drive wheels: AWD, FWD
Engine: 1ZZ, 2ZZ
Edit: Matrix and Corolla ECU's should also work for your car, but they have to match your equipment.
Re: Vibe Computers
Posted: Tue Nov 27, 2012 1:13 pm
by blankmonkey
LOL not really, just Katrina/Sandy/other
Are there any other computers I should know about?
Re: Vibe Computers
Posted: Tue Nov 27, 2012 5:08 pm
by SeattleJeremy
In that situation the cars computers are the last thing to worry about. They are well hidden in the dash.
If the ECU or other computers get wet, the rest of the car is a write off anyway. Also, they are easy enough to come by on ebay or car-part.com or local wrecking yard if it does come down to that.
If your car gets submerged high enough to short the electronics, then there would be water everywhere. Crank case, transmission, gas tank, intake, exhaust, sensors. Quickly swapping out the ECU in an emergency is not going to get the car running again.
In the case of Katrina/Sandy Shelter, Water, and Food should be first on your list. Next would be Gasoline. After big events the power usually goes out so gas stations can't use the pumps to get gasoline.
Re: Vibe Computers
Posted: Wed Nov 28, 2012 5:15 am
by hotbug1776
Also, if you are thinking of saving the car in the event of an EMP, there are so many things that will be affected, you would be better off putting the whole car in a giant electronics bag. Lol
