2009 Monsoon Head Unit Question
Posted: Mon Nov 12, 2012 10:47 pm
by MannyL
Anyone have a diagram of the head unit wiring? My audio in jack is damaged and I want to bypass it with an external jack. I'm not sure where to run the wires on the HU once my friend has it pulled.
Re: 2009 Monsoon Head Unit Question
Posted: Fri Nov 16, 2012 9:09 am
by viboflavin
Is it physical damage to the port?
If so, your best bet is probably to get right behind where it goes into the unit and solder leads to a new input.
I once took a CD audio output (from the disk tray) and soldered in an 8th inch female jack and trust me, you don't want to be messing with the circuit board if you don't have to.
Posted: Mon Nov 19, 2012 10:59 pm
by MannyL
viboflavin wrote:Is it physical damage to the port?
Yes it is physically damaged.
