Driver side power power window noise
Posted: Mon Nov 12, 2012 9:20 am
by bniesch
I have an '09 base Vibe. Anyone out there ever have this occur to them?
When I put my driver side power window up and stop pressing the button, the window motor seems to stay engaged and continues to push up on the window making a loud, creeking sound. To avoid this I must stop just short and lightly tap the button until I know it is up or else it keeps cranking for a second or two.
Thanks
Bruce
Re: Driver side power power window noise
Posted: Tue Nov 20, 2012 3:19 am
by Caretaker
no, but I believe there is another Toyota recall out there for Corolla driver's side window switches. Check it out on our Vibe "Latest News" thread:
http://www.cleveland.com/business/index ... er_default" onclick="window.open(this.href);return false;
Posted: Thu Dec 13, 2012 11:49 am
by SeattleJeremy
bniesch wrote:I have an '09 base Vibe. Anyone out there ever have this occur to them?
Thanks
Bruce
Bruce, you need to have that checked out asap, there is a recall on that window switch, and it can start a fire.
viewtopic.php?f=41&t=39715" onclick="window.open(this.href);return false;
Call your dealer schedule it, and they should have it fixed in about an hour.
Posted: Thu Dec 13, 2012 1:11 pm
by ParknVibe
Thanks
Bruce
I have the same issue such that the glass keeps moving to completely open the window after I stop pressing the switch. This, I beleive is part of the design of the system. You just have to release the switch very quickly to make it stop moving. However, I don't like it at all.
The sound could be dirt in the glass tracks or weatherstripping. However you could have that loose bolt problem that was a recall on earlier models inside the door. I hope I don't get it someday.
Posted: Sat Dec 15, 2012 1:48 pm
by vibenvy
There is a recall for the master window switch on the driver's side door panel on 2009 Vibes. Just as SeattleJeremy said, you should call your dealer and schedule an appointment to have it checked out ASAP.
