How/Where do you store your summer/winter tires ?
Posted: Thu Nov 08, 2012 4:25 pm
OK. Several of us GenVibers have TWO sets of tires for our Vibes. Now in my case I got tired of taking them up into the attic above the garage (pull down steps & low 4/12 roof = bang head several times
). So I cleared up the south wall on my 18' x 20' small two car attached garage so that I could fabricate a rather unique "racking system" to store my tires. Well I just got it done and it came out better than what I had imagined. The pics pretty much tell the story:
This first photo shows the rack bolted to the wall studs very close to the ceiling. This is nothing more than
some 3/4 black pipe welded to a length of angle iron. Tire centers are 25.5" apart and the angle iron is bolted
to the wall using the common 16" on center stud measurements
This photo shows the 1"PVC sleeve which I attached to all of piping holders. I merely cut some 6" pieces and
with a torch, heated the one end up to where it got "soft U gummy" then slid it over the pipe. This allowed
it to "bend at the contour" and this also then eliminates any steel to steel contact during storage.
Here are the four "winter tires" safely & cleanly stored until needed
As an added measure of insurance, I drilled 1/4" holes and have a bolt, acting as a pin, to assure that the wheels
will not ever want to "slide off" the pipe. This also keeps them tight against the wall
Oh yeah ....... Don't forget the wheel covers!!! There you have it. A nice affordable & good looking system to store
both your summer AND winter tires.
