HELP: Are base and AWD Vibe Struts/assembly the same??
Posted: Sun Nov 04, 2012 7:10 pm
by pointbob
Can I interchange them? Specifically the front suspension.
Re: HELP: Are base and AWD Vibe Struts/assembly the same??
Posted: Mon Nov 05, 2012 9:25 am
by BlueCrush
The fronts are exactly the same. The AWD Rears (top hats) are different with 3 bolts vs. the FWD's 2 bolts.
Posted: Mon Nov 05, 2012 9:36 am
by pointbob
Thank you!
Weird thing tho...Apparently the OEM parts by GM (according to two gm parts dealers I spoke to) are different part numbers for both AWD and reg FWD.
But, the aftermarket makers like Monroe and KYB say their front struts are interchangeable with awd/fwd.
Why the discrepancy/different part numbers thru GM but not aftermarket makers?
