port and polish
Posted: Sun Jul 20, 2003 7:23 am
by dmitri
I've done it myself on my camaro and someone elses car. It came out real well. I'm planning on doing it on my vibe gt. Is there any special coating on the heads (like on the block because you cant bore it)? Is there anything special to watch out for on our heads?Thanks.
Re: port and polish (dmitri)
Posted: Mon Jul 21, 2003 2:19 am
by dmitri
??? why no replys???
Posted: Mon Jul 21, 2003 2:22 am
by Big_Red
....uhm...I don't really know what you are talking about....but that's just me.
Posted: Mon Jul 21, 2003 4:11 am
by cohocarl
quote:Is there anything special to watch out for on our heads?My guess is that the intake and exhaust ports on the 1zz and 2zz motors are about as good as you are going to get as is. These aren't 30 year old designed sbc heads.
Re: port and polish (silverawd26)
Posted: Mon Jul 21, 2003 5:14 am
by dmitri
im sure they dont perfect it at the factory, its just cast and thats it. But are there any coating on it, or anything different then a chevy head because of lift and stuff? Im planning on using a dremel tool to grind it down a little bit, then polish it with fine grit on the dremel. maybe ill polish the intake manifold runners too.
Posted: Mon Jul 21, 2003 5:17 am
by satur9
i believe i read somewhere about laser inlaid valve seats rather than pressed in. whether or not it affects a port and polish i wouldnt know. if it was me i wouldnt touch anything on the 2zz. i'd might give it a go on the 1zz though
Re: port and polish (satur9)
Posted: Mon Jul 21, 2003 5:20 am
by dmitri
then i wont go in the combustion chamber, ill just do the intake and exhaust ports...if i do go in the combustion chamber i think ill stay away from the valves...Im thinking of doing the intake manifold but how do i get in there?? the dremel has that extention thing but i dont kno
Posted: Mon Jul 21, 2003 6:56 am
by mitro
No part that is cast can be perfect, I'm sure there spots that could use some touching up, perhaps some port matching, but you don't want to go hogging out anything, as the 2ZZ is designed to breathe well from the factory.
Re: port and polish (mitro)
Posted: Mon Jul 21, 2003 11:05 am
by dmitri
Nova...u know anything about this? your usually full of info.
