Vibe Headlight spring retainer tab broken
Posted: Mon Oct 22, 2012 6:57 am
by mcdan
In replacing a headlight bulb, the small cast tab that the retainer spring hooks onto is broken. Headlight bulb is not secure as it should be without the spring retainer putting pressure on the bulb to keep it inplace. Is there anyway to correct/modify/adapt the spring clip to hold the bulb in place without the tab? Hopefully there is some way without replacing the entire headlight assembly. Thanks for any help ...
Re: Vibe Headlight spring retainer tab broken
Posted: Mon Oct 22, 2012 9:57 am
by keithvibe
nope no way to fix it.
You could try rig something but that plastic tab you are talking about is part of the reflector bucket and isn't fixable.
You could try using some jb weld on the piece. It may work for a short time but it will break eventually.
Posted: Mon Oct 22, 2012 4:32 pm
by thebarber
Time to retrofit projectors
Posted: Tue Oct 23, 2012 4:41 pm
by keithvibe
thebarber wrote:Time to retrofit projectors
sounds like a good idea :lol:
Posted: Wed Oct 24, 2012 6:46 am
by thebarber
well, as of last night i have an H4 projector retrofit kit in stock. they sent it to me with the wrong colour of halos for my customer. its a 4300k bulb, blue halos, H4 wiring harness
PM if you're interested...
