Equipment Details of AWD Models
Posted: Sun Oct 14, 2012 11:24 am
by xspirit
I'm probably going to buy a Vibe, and it would be in the Canadian market.
On the "must have" list are:
- awd
- stability control
- folding front passenger seat
- the more airbags the better
I'm hoping you experts on these cars can ensure the accuracy of what I've learned about them so far.
- Two generations: 2003 to 2008, and 2009-2010
- awd version available in all the years except 2007 and 2008
- in 2009, awd available on base version only
- awd version 2009-2010 equipped with 4-spd automatic and 2.4L engine only
- stability control was a $1000 option on the first generation starting in 2005, standard on the 2009-2010
- very few of the first generation awd models had the stability control option
- side curtain airbags were available as an option starting with the 2005, standard on the 2009-2010
- all the first generation models had the fold-flat front passenger seat
- 2009's have fold-flat front seat with 2.4l engine, all 2010's have it
I like the styling of the first generation much better than the second generation, but if the combination of features I want is just too rare on the first generation, then I'd have to get used to the bunker design of the 2009-2010.
Re: Equipment Details of AWD Models
Posted: Sun Oct 14, 2012 1:55 pm
by zyzyix
Hi:
AWD for the Vibe was from 2003-2006. AWD and the sporty models were gone for 2007 and 2008 1st Gen. AWD was reintroduced for 2009 base model Vibes only.
I'm not quite sure, but I believe stability control was first offered in 2005, side air bags being offered for starting in 2005 as well.
Gen for Vibes- 1st-2003-2008, 2nd-2009-2010
Posted: Sun Oct 14, 2012 5:00 pm
by 09vGT
I have an 2009 GT but I do know that all of the trims have the front & rear side curtain and front, seat mounted, thorax airbags. Also included, as you have said, is stability control, traction control, and ABS. I have no idea on the folding flat front seat. I know mine does, but the GT's pretty much had all of the options, minus the AWD.
Posted: Sun Oct 14, 2012 5:07 pm
by vibenvy
I am not sure on exactly which 2009-2010 models have the fold flat front passenger seat. I know it was standard on all GTs, but I'm not 100% sure on how it worked with the AWD models.
I do know that all 2009-2010 AWD models are only available with a 4-speed automatic transmission. In addition, they all have a 2.4L engine, 5x114.3 bolt pattern for the wheels and IRS (Independent Rear Suspension).
Posted: Sun Oct 14, 2012 5:20 pm
by xspirit
Thanks for the excellent feedback. That's the sort of info I was looking for. I'll update my "list" in the op as it comes in.
A question outside the equipment list, is: do the Vibe's engines have timing belts and what is the replacement interval? It's common for people to sell used cars just as this comes due.
Posted: Sun Oct 14, 2012 5:43 pm
by vibenvy
I believe I have read on here that they all have timing chains...
Posted: Sun Oct 14, 2012 5:46 pm
by xspirit
vibenvy wrote:I believe I have read on here that they all have timing chains...
Excellent.
Posted: Mon Oct 15, 2012 1:55 pm
by zyzyix
xspirit wrote:Thanks for the excellent feedback. That's the sort of info I was looking for. I'll update my "list" in the op as it comes in.
Timing chain,
Yes, some owners will try to sell a car before a timing belt replacement would be due. On some cars this service can be costly due to the many components that have to be removed to get to the belt.
Posted: Mon Oct 15, 2012 2:49 pm
by Scwmcan
From what I can recall from my research this summer, the only 2009 vibe that didn't come with the fold flat front seat was the base 1.8l models, all the 2.4 l models had it which of course includes the AWD.
Posted: Tue Oct 16, 2012 11:08 pm
by xspirit
Along the way I've figured out that all the AWD models have an AWD badge on the hatch. The 2005/2006's with VSC/Stabilitrac have warning lights that show up when the ignition is turned on, and a Traction Control off switch in the lower left corner of the dashboard. This will help a lot because ads often don't mention these things or have them wrong.
