Trouble Closing Engine Air Filter Hood
Posted: Sun Oct 07, 2012 7:05 am
by kjb32121
Hey everyone,
I'm new to the board and could use some help. I've replaced my engine air filter a few times on my 2003 vibe, but when I recently changed out the filter, I noticed that the housing hood doesn't completely sit an seal around the filter compartment. I can see some of the air filter, but the clips did clamp down. I messed with the hood for some 30 minutes, and I could not get the clamps to secure unless the hood was in this position, partially open. I've never notice before, but is this normal? Or does should the whole unit be sealed down? I know it sounds silly, but the hood is very secure even while partically open, but I just CANNOT get it to completely seal all the way around.
Thanks !
Re: Trouble Closing Engine Air Filter Hood
Posted: Sun Oct 07, 2012 7:49 am
by Flip-Side
Pull the top of the air box off far enough to look at it's bottom. The edge plastic somtimes breaks and bends to the side, causeing it to not seat properly. If this is the case, break the peice off, throw it away, and put the airbox back together.
Otherwise, just make sure you have the feet slid all the way into the notches on the bottom half, align the top half, and close.
Posted: Sun Oct 07, 2012 8:07 am
by kjb32121
Thanks, I'll take a look. Maybe it's the feet too. The feet don't seem to notch right. But i'll check it out and snap a picture if it keeps giving me problems.
Posted: Sun Oct 07, 2012 8:59 am
by star_deceiver
There should be a tab in one of the corners on the filter, make sure it'sin the right place in the housing.
Posted: Sun Oct 07, 2012 2:54 pm
by kjb32121
Hmm...I installed the new filter exactly like I had the old filter. I double checked the filter and it sits perfectly in the bottom of the housing...but when i try to close the top it's still raised near the feet. Now, it appears as if it is sealed, in the sense that even though I can still see some of the white of the filter near the feet (and the tabs are locked in the front) the housing isn't moving so maybe other air and dirt won't get in? Maybe it's always been this way and i never noticed?
Right now the feet don't actually lock into their hinges, are they supposed to? They just sit on the hinges right now. (And when I mean the feet, I mean the left side of the housing, not the 2 metal clamps on the right side.)
Arg
Posted: Sun Oct 07, 2012 10:00 pm
by star_deceiver
Did you compare the new filter to the old one? Sometimes the manufacturers change producs slightly or you may have a defectivly made filter.
The latches on the filter housing should close.
