				Just bought new tires
				Posted: Sun Sep 30, 2012 1:52 pm
				by regnac
				http://herculestire.com/catalogHercules ... ur655.html" onclick="window.open(this.href);return false;
Friend owns a tire shop and loves these.
NATIONAL replacement coverage,  low friction, all weather and I got the 215/50/17 for my Vibe.
The difference from 205/45/17 on Michigan roads is a dramatic improvement.
oh and MADE IN THE USA!  (Ohio)
				Re: Just bought new tires
				Posted: Sun Sep 30, 2012 6:18 pm
				by star_deceiver
				Google has nothing on them.
How much, and what did they replace?
				Posted: Mon Oct 01, 2012 3:03 am
				by regnac
				They replaced the 205/45/17 like I said in first post....
$481 out the door
 They ride a lot better!  I will take pics later today and post.
				Posted: Tue Oct 02, 2012 11:22 am
				by DennisLee
				What percent do you figure for the speedometer impact?  I think I'll need new tires before we get much snow.  The Sumitos that were on the car when I bought it are noisy as heck and are deadly in the rain (as in, you could be dead if you don't slow down).  I like the idea of a little more sidewall to cushion the ride.
				Posted: Wed Oct 03, 2012 6:28 am
				by Scwmcan
				From when I looked into it 215/50/17s are over the 3% recommended difference in diameter, not by much though, if that is okay with you(wasn't for me). A205/50/17 size is fine if you want a 50 aspect ratio.
				Posted: Wed Oct 03, 2012 1:53 pm
				by regnac
				DennisLee wrote:What percent do you figure for the speedometer impact?  I think I'll need new tires before we get much snow.  The Sumitos that were on the car when I bought it are noisy as heck and are deadly in the rain (as in, you could be dead if you don't slow down).  I like the idea of a little more sidewall to cushion the ride.
Road noise is WAY down,  bumps cut in half if not more for sure
As for speedometer I figure yeah 3% but I do speed limit or plus 5 most of the time so should be okay.....   I guess I could have it re-calibrated somehow?   I am unfamiliar with that area.
				Posted: Thu Oct 04, 2012 12:22 pm
				by Kincaid
				Looks good!  I do not think there is an easy fix when a speedo is off - then again most of these 2009-10's seem to have inaccurate speedos anyway!  Mine registered a constistent 3 mph higher than what I was really doing almost across the entire range of speeds.  I suggest using a GPS (borrow one if you need) to check against your speedo and then when you know how far off it is, drive accordingly.
				Posted: Fri Oct 05, 2012 2:54 am
				by regnac
				Kincaid wrote:Looks good!  I do not think there is an easy fix when a speedo is off - then again most of these 2009-10's seem to have inaccurate speedos anyway!  Mine registered a constistent 3 mph higher than what I was really doing almost across the entire range of speeds.  I suggest using a GPS (borrow one if you need) to check against your speedo and then when you know how far off it is, drive accordingly.
Thats a great idea,   I have GPS on my Android but probably not as accurate as a TomTom or similar.   My dad has one so may have to borrow his.
