05 front grill removal
Posted: Sat Sep 29, 2012 12:18 pm
by Sparkeyoo7
Would like to know if there is any special procedure in removing front grill on an 05 I want to paint them black thanks in advance.....
Re: 05 front grill removal
Posted: Tue Oct 02, 2012 5:48 am
by Mariachi
you have to remove the two bolts located at the bottom of the image:
then from here, you have to start unclipping all of the clips from the right side, i believe, first then the left side of the grill. both are attached to each other.
lemme know if you have problems. I think someone made a how to but if not, I can try to strum one up for ya
Posted: Fri Oct 05, 2012 3:51 pm
by Sparkeyoo7
Thanks for the info I will tackle it over the weekend if I have issues I will ask thanks in adveance..
Posted: Fri Oct 05, 2012 3:53 pm
by Sparkeyoo7
By the way I forgot Miriachi you have a really SWEET RIDE!!!!!!!
Posted: Sat Oct 06, 2012 8:28 am
by Mariachi
thank you.
I am actually not there yet. My sig was photoshopped with the wheels i want and stanced like i want.
I should be getting my wheels on the car soon. i have the same corvette wheels and probably just going to fix the bend on the wheels before polishing and sanding to get the wheels on. we will see but thnx! the sig is my goal
