				225/45/17 Tires
				Posted: Fri Sep 28, 2012 6:16 pm
				by Sparkeyoo7
				Will be purchasing mags very soon to upgrade my original 16" to 17" I was wondering if there would be any rubbing issue with the wider 225 dimension thanks in advance...
				Re: 225/45/17 Tires
				Posted: Sat Sep 29, 2012 5:51 am
				by thebarber
				Sparkeyoo7 wrote:Will be purchasing mags very soon to upgrade my original 16" to 17" I was wondering if there would be any rubbing issue with the wider 225 dimension thanks in advance...
Inconvenience 17x8 wheels with a +48 offset, 25mm spacers in the rear and am lowered on tein h-tech's.   No rubbing issues on 225-45-17
				Re: 225/45/17 Tires
				Posted: Sat Sep 29, 2012 8:27 pm
				by trb
				I actually put some 245/45/17s on my son's Vibe and he has no rubbing issues that we've noticed, and they've been on there for several months.  Granted, the tires are technically too wide for the 17x7 wheels, but they were paid for and just wasting away on my Mustang so I decided to go for it.  So 225s should fit great.
				Re: 225/45/17 Tires
				Posted: Sun Sep 30, 2012 1:20 pm
				by ramenboy...
				Imrunning 235 45 17 on my o4 and it's also lowered on tein s-tech springs.
No probs at all.
Go for it!
				Re: 225/45/17 Tires
				Posted: Sun Sep 30, 2012 5:35 pm
				by Sparkeyoo7
				Thanks buddy I have the same in mind  Tein s tech springs how is the ride though after installing them ??
				Re: 225/45/17 Tires
				Posted: Sun Sep 30, 2012 7:17 pm
				by ramenboy...
				Ride is tight. Not 'cushy' like the stock springs and 16s. But not bad at all. And with just the springs alone (no sway bar) handles nicely. Like a slot car. Exit ramps are alot more fun:p
				Re: 225/45/17 Tires
				Posted: Mon Oct 01, 2012 4:10 am
				by thebarber
				Sparkeyoo7 wrote:Thanks buddy I have the same in mind  Tein s tech springs how is the ride though after installing them ??
For reference, my signature I'm on h-tech's.  OEM comfy, but OEM soft
				Re: 225/45/17 Tires
				Posted: Mon Oct 01, 2012 10:24 am
				by Kincaid
I am assuming you have the first generation Vibe?  (Because you didn't say different with other first generation owners commenting).
*edit*  Oh, now I see your introduction thread.  Congrats on the 2005 Vibe!
I have a 2009 Vibe running on Tien H-Tech springs.  No problems with stock 17" alloys and original 215/45-17 tires.
Then I went to 225/45-17 replacement tires (mostly because I wanted a bit more protection for the wheels from getting curbed).  I get some kind of rubbing with the front driver's tire but it is only audible when I'm backing up and with the wheel turned in the middle range - you can't hear it when I am backing up straight and when turned all the way the sound stops.  I was surprised to have anything interfere because the tires is only 10mm wider and only 4.5mm larger in overall diameter.  This is just 1.45% larger overall according to the 1010.com tire size calculator.
I need to get the wheel off and see if there is any easy fix.  If not, I can live with it.
				Re: 225/45/17 Tires
				Posted: Mon Oct 01, 2012 4:56 pm
				by Sparkeyoo7
				Yup it's a 05 my vibe and I am really steering towards the s-tech springs and the 225's that's for sure I really can't wait for spring it will all come alive  I will certainly post pics when the time comes
				Re: 225/45/17 Tires
				Posted: Tue Oct 02, 2012 4:43 pm
				by thebarber
				Kincaid wrote:Sparkeyoo7 wrote:Will be purchasing mags very soon to upgrade my original 16" to 17" I was wondering if there would be any rubbing issue with the wider 225 dimension thanks in advance...
you're likely rubbing on the plastic fender lining...check to see if its scuffed from rubbing
				Re: 225/45/17 Tires
				Posted: Tue Oct 02, 2012 5:53 pm
				by ramenboy...
^this. When i got into the accident over the summer, things were pushed back a little, and I did get rubbing on the highway. But once repaired, everything was fine
				Re: 225/45/17 Tires
				Posted: Wed Oct 03, 2012 4:38 am
				by Mariachi
				when i first lowered my vibe with the tein s-techs and the 18x7.5 MODWheel GFO2's, i had 225/40/18 and i rubbed on the plastic wheel wells just a bit but I just cut a whole where they were rubbing and problem solved. didn't rub anywhere else.
				Re: 225/45/17 Tires
				Posted: Wed Oct 03, 2012 12:22 pm
				by Kincaid
				That's what I figured but am hoping it is something I can do without compromising the liner.  My Civic is lowered and because of the wide wheels I had to cut the fender liner tops out and I get a lot of debris down in either side that I have to hose out all the time.  Grrrr.
				Re: 225/45/17 Tires
				Posted: Wed Oct 03, 2012 10:48 pm
				by thebarber
				the rubbing problem fixes itself, eventually...
my vgt had a hole in the driverside liner when i bought it....the previous owner had smucked something on the road and it broke some of the plastic clips on the fender lining/under panels, so it rubbed a nice hole in the liner with 205-55-16's on oem wheels
