Where can I find our belt pattern?
Posted: Fri Jul 18, 2003 9:57 am
by Pablo1669
I just replaced all my pulleys with the UR underdrive pulleys, and I don't remember the belt pattern, and can't find pictures of it... can anyone get me a picture of the GT set up if it differs from the Base?
Re: Where can I find our belt pattern? (Pablo1669)
Posted: Fri Jul 18, 2003 10:18 am
by ragingfish
I believe it is located on the underside of the hood...
Re: Where can I find our belt pattern? (ragingfish)
Posted: Fri Jul 18, 2003 10:25 am
by Pablo1669
quote:I believe it is located on the underside of the hood...I can't find it anywhere under, check and see in yours but I definately can't find it. I did see the air hose routing or something like that though
Posted: Fri Jul 18, 2003 10:26 am
by cohocarl
I just tried searching for a pic of a 2zz with a pic of the serpentine belt, but can't find any. There's probably nothing in the owner's manual is there? Some cars have a sticker on the inside of the engine compartment with a diagram of how the belt goes, but I don't remember if the Vibe has one or not.
Re: Where can I find our belt pattern? (cohocarl)
Posted: Fri Jul 18, 2003 10:41 am
by Pablo1669
quote:I just tried searching for a pic of a 2zz with a pic of the serpentine belt, but can't find any. There's probably nothing in the owner's manual is there? Some cars have a sticker on the inside of the engine compartment with a diagram of how the belt goes, but I don't remember if the Vibe has one or not. nothing in the owners manual or under the hood... I tore em both apart tryin to find one
Posted: Fri Jul 18, 2003 10:48 am
by NSimkins
I saw this in the Service Manual.. the image shows the same for both the 1zz and 2zz... can't verify if they are identical (belt wise) in reality or not.
Re: Where can I find our belt pattern? (NSimkins)
Posted: Fri Jul 18, 2003 11:14 am
by Pablo1669
hey, that worked... too bad I don't have a perfect fit on the belt. Damnit... good find though, tomorrow I'll have the right size belt for sure.
Posted: Fri Jul 18, 2003 3:31 pm
by ragingfish
You're right, I just checked under the hood, stupid vacuum hose routing diagram. First car I had that DIDN'T have belt routing there...screwy.If you want, I can take pics of my engine belt routing (since I'm all stock on that side) for you to get an idea...lemme know...
