				Factory Radio stopped working
				Posted: Sat Sep 15, 2012 11:56 am
				by OLimoges
				Hi, I'm new to this forum, but I saw this forum and I decided to tell a little problem that I just got today with my Pontiac Vibe '06 based model.
I started my car and tried to put the volume up, but then the red screen just went out ! I tried all the button on the radio but nothing worked. I noticed that the cd slot is still working but when I put the cd back in the radio nothing happenned !
I just want to know if I can repair this simply or I need to get a new radio, if so do you have any idea wich one works fine with the based model speakers ?
Tks a lot
				Re: Factory Radio stopped working
				Posted: Sat Sep 15, 2012 4:36 pm
				The first thing I'd check is the fuse.  The radio gets power from the CIG fuse which is under the left side of the dash, and hard to access.  You can also tell if the fuse is good by testing to see if the 12 V cigarette lighter/power outlet near the shifter has power.  That outlet and the radio get power from the same fuse.  I have tried bad connectors in that outlet, blown the fuse, which kills power to the radio
				Posted: Sat Sep 15, 2012 6:15 pm
				by OLimoges
				I think this is the problem, because my power mirror stopped working too !
I tried to find the fuse panel, but I removed the wrong panel, near the left foot, just at the left of the footrest thing ! I unscrewed the plastic cap, but I can't screwed it back...
I don't know why, but the plastic cap that cover all the lower portion of the door is moving a little bit and it frustrates me.
Is it normal ?
tks
				Posted: Sun Sep 16, 2012 3:15 pm
				by bluneon
				that nut isn't meant to be screwed back on. you just push it straight onto the stud. the barbs inside the nut will hold it in place.
the interior fuse panel is behind the knee panel. you'll need to stick your head all the way inside and look straight up. you'll see the fuse panel.
				Posted: Mon Sep 17, 2012 12:56 pm
				Yeah, that interior fuse panel is a pain to get to.  Just for reference sake, on the left side of the steering wheel, lower than the power window controls, there is a small storage compartment.  I you were to remove that plastic bin, you could see the top of an electrical junction box.  The fuses you need to check are on the underside of that junction box.  It won't do you any good to remove that bin, you can not access the fuse block that way.  I only mention it because that should help you understand where the fuse block is.  When you lie on your back and look up inside the dash for it, you will likely see a black plastic cover that you'll have to press the clip on one side to remove and access the fuses.
You waid that the radio stopped working, and also that the power mirror controls are not working either.  The two may be related, caused by one single problem, or they may be two independent problems.  Check everything you can that is electrical, see if anything else is not working.  That will help folks here try to locate a potential single failure that can cause all the electrical problems.
Did you ever try to see if the 12V outlet/cigarette lighter thing still works?
				Posted: Wed Sep 19, 2012 5:32 pm
				by OLimoges
				TKS guys, I find the fuse panel, not easy to find and to get the fuse out
Everything works fine now, it was just the fuse !
Tks again boys
