Jammed hatchback door
Posted: Thu Sep 13, 2012 6:43 pm
by trailrider650cc
Hi everyone, I am new here and happy to see this forum exist. I just bought a nice red 2004 Pontiac Vibe; I love it. But a couple of weeks after my purchase; the hatckback door jammed. I feel a tension on the handle but no click. I tried with the key; no success. Tried with the inside button; the window open normally but not the door. I do not know if any of you experienced this before? I would like to remove the inside panel but the door is closed; do you think it possible?
Thanks for your help.
Re: Jammed hatchback door
Posted: Thu Sep 13, 2012 7:45 pm
by A Psycho Martyr
nah, you're not gonna be able to remove the panel w/ the hatch closed
I'd wiggle the key until ya get it (don't break that key tho)
Posted: Thu Sep 13, 2012 7:53 pm
by KITT222
The tiny access panel you for sure can pop off while the hatch is closed. That should be enough to reach in and pull the latch free.
Posted: Thu Sep 13, 2012 7:58 pm
by A Psycho Martyr
I should have taken pics when i had mine off so i could tell him EXACTLY where the rod is in there
Posted: Fri Sep 14, 2012 3:55 pm
by trailrider650cc
OK. I know what little access panel you are talking about. I will try this weekend and let you know the outcome. Thanks for your advises and I hope it open. Then I will need to understand what happened!!!
Posted: Sun Sep 16, 2012 1:40 pm
by trailrider650cc
Finally fixed it!
It was part of a plasitc screw (the ones holding the plate in place) that fell down and blocked the unlockingh system. I was also able to remove the whole plastic door trim even if the door was closed. I needed that otherwise there was no way I could have seen what was going on down there. Once that little (removed) was removed; the door work again!!!
Again; thanks for your tips!
