I need some help...will these fit?
Posted: Fri Jul 18, 2003 1:07 am
by CaCathy13
18" x 8 +21 mm offsetCan anyone help?
Re: I need some help...will these fit? (CaCathy13)
Posted: Fri Jul 18, 2003 3:48 am
by yank dini
no 18 x 7 5 over 100is our size
Re: I need some help...will these fit? (silverawd26)
Posted: Fri Jul 18, 2003 5:02 am
by CaCathy13
well I know the bolt pattern is 5x100I am concerned with the 8 width... yank, Geo got his new Mille Miglias and they are 17x8 and they fit. I knew x7 and x7.5 would fit but I am concerned abotu the 8. I ca;;ed wheelmax and they said they'd fit the Vibe... but I wanted to know if other people have 18x8 on their Vibes and if they fit.
Re: I need some help...will these fit? (yank dini)
Posted: Fri Jul 18, 2003 5:08 am
by NovaResource
Hold on a second. We're discussing different numbers. The bolt pattern for our Vibes is 5 on 100mm. That means 5 holes in a 100mm diameter circle. The +21mm Cathy listed is the offset. That is the distance away from the center rim that the mounting surface is.My wheels are 17x7 with a 38mm offset. 7" wide rims is approx 178mm wide. Divide by 2 and you get 89mm to the rim center. Add the 38mm offset and you get 127mm from the mounting surface to the inner rim lip.The wheels Cathy is asking about are 18x8 with a 21mm offset. 8" wide rims is approx 203mm wide. Divide by 2 and you get approx 101.5mm to the rim center. Add the 21mm offset and you get 122.5mm from the mounting surface to the inner rim lip.This means those rims have 4.5mm more clearance on the inside. However, the rims are 25mm wider. Add 25mm plus the 4.5mm extra clearance and you get rims that stick out 29.5mm farther than my wheels. 29.5mm is approx 1-5/32".I'd say they would fit with no problem with either 215/40-18 or 225/40-18 tires.
Re: I need some help...will these fit? (NovaResource)
Posted: Fri Jul 18, 2003 5:11 am
by Shadow Realm
Nova,Did we find out if the rims were 5 x 100?Shadow Realm
Posted: Fri Jul 18, 2003 5:33 am
by CaCathy13
Thanks Nova...very informative! That totally helped me understand it. BTW, I'd be getting a 225/40/18 tire...Now I just have to decide on silver or chrome...$1399 vs. 1699Such a big step!
Re: I need some help...will these fit? (Shadow Realm)
by NovaResource
quote:Did we find out if the rims were 5 x 100?She didn't post that but I assume they are or she would have asked about that. I think she knows the correct bolt pattern needed.Cathy, are they 5 on 100 bolt pattern wheels?
Posted: Fri Jul 18, 2003 5:37 am
by NovaResource
225/40's will look nice and the wider wheels with have them sticking out a little more than an inch compared to mine. I think that will look sweet. Personally, I like painted silver compared to chrome because they are easier to maintain (chrome rusts in the winter here). On the other hand, chrome looks better on dark cars like your Neptune. I guess I'm not much help on that decision. LOL!
Posted: Fri Jul 18, 2003 5:55 am
by satur9
i asked a question about a wheel and offset a week ago and NOBODY answered.mabey if i was a girl i would have got a answer. but anyway mabey i get some help here! using novas math with a 42mm offset it seems i lose 4mm of inside clearence less than a quarter of a inch. my question is i lose this between the inside edge off wheel and strut. i stuck my fingers in there i dont think 4mm with hurt anything. but does 4mm offset difference affect caliper clearence,or does that stay the same.
Re: I need some help...will these fit? (satur9)
Posted: Fri Jul 18, 2003 11:28 am
by NovaResource
You need to tell us the rim width. If it's a 7" wheel, you, you will loose 4mm on the inside. If it's a different rim width you'll have to calculate. About caliper clearance, you'll have to ask the manufacturer.
Posted: Fri Jul 18, 2003 11:50 am
by Geo
quote:Thanks Nova...very informative! That totally helped me understand it. BTW, I'd be getting a 225/40/18 tire...Now I just have to decide on silver or chrome...$1399 vs. 1699Such a big step!Ya know what they say "Chrome won't get ya home!"Well, at least that was an old Jeep saying ...I vote for the silver paint, but that's just my personal preference, I don't see many chrome wheels out there that I care for
Re: I need some help...will these fit? (Geo)
Posted: Fri Jul 18, 2003 2:06 pm
by rasermon
quote:I don't see many chrome wheels out there that I care for Geo, what about this chrome wheel. I like it.... pissedoffgokart's wheel
Re: I need some help...will these fit? (rasermon)
Posted: Fri Jul 18, 2003 2:39 pm
by Geo
quote:I don't see many chrome wheels out there that I care for Geo, what about this chrome wheel. I like it.... *claws his eyes out*Well, mb not that bad. But I wouldn't put that on my vehicle.I just have a problem with chrome wheels on cars ... go figure!
Posted: Fri Jul 18, 2003 9:40 pm
by rasermon
quote:*claws his eyes out*Well, mb not that bad. But I wouldn't put that on my vehicle.I just have a problem with chrome wheels on cars ... go figure!
*wiping tears from eyes*Thanks for your honest opinion. My guess is, Cathy will go with chrome. Geo's vibe with 20's
Posted: Fri Jul 18, 2003 9:45 pm
by MadBill
That lost 4 mm clearance won't hurt a bit, satur9! The inner flanges of my 17" x 10" rims are 34 mm (~1-3/8") tighter to the struts/fender wells than Nova's (stock offset?) 17" x 7s, and although pretty tight, in 10,000 km I've never had a problem. BTW, the outer flanges of my "steamroller rims" are 42 mm or ~ 1-5/8" further out, and with a 275/40 tire, my suspension travel is limited somewhat by fender lip clearance, especially on the front. If I was buying new, I would have tried to go with a max of 245/40s on an 17" x 8" with around + 35 to 40 mm offset. (Nice use of mixed units there!)
Posted: Mon Jul 21, 2003 4:41 am
by yank dini
what's the tire size on those?
Posted: Mon Jul 21, 2003 5:24 am
by rasermon
Yank, I photo-shop the wheels on Geo's vibe. I'm not sure what size they would be. I was messing with Geo's mind....
Posted: Mon Jul 21, 2003 5:40 am
by yank dini
quote:what's the tire size on those? I believe those are 20's that he pasted on there.yeah but I meant the tire sidewall and all that it's gotta be at least a 35 unless he did some adjustments
