cluster going crazy
Posted: Fri Aug 10, 2012 1:05 pm
by felixturcotte22
My 2005 Vibe was subject to a recall for the Ecm due to security issue. When I had it changed, my cluster went crazy and the rpm needle was going from 1k to 5k but the engines wasn't leaving 1k. Any ideas ?
Re: cluster going crazy
Posted: Fri Aug 10, 2012 1:34 pm
by Mariachi
felixturcotte22 wrote:My 2005 Vibe was subject to a recall for the Ecm due to security issue. When I had it changed, my cluster went crazy and the rpm needle was going from 1k to 5k but the engines wasn't leaving 1k. Any ideas ?
take it back to the dealer. How long ago was this that you got the PCM recall fixed?
Posted: Fri Aug 10, 2012 3:19 pm
by felixturcotte22
RISCVibe wrote:felixturcotte22 wrote:My 2005 Vibe was subject to a recall for the Ecm due to security issue. When I had it changed, my cluster went crazy and the rpm needle was going from 1k to 5k but the engines wasn't leaving 1k. Any ideas ?
4 months ago but it did it once and stopped so I figured it wasn't that bad until it did couple days ago, the problem is that the warranty is over for that recall.
