NEED PCM HELP!!!!
Posted: Fri Jul 06, 2012 9:35 pm
by Zvibe2004
im the guy who just swapped my vibe from a automatic to a 6 speed, and i need to find someone that can reprogram my computer so it runs properly all the time and doesnt think the automatic just went poof-gone. from what ive found a toyota performance tuner, a guy that actually tunes toyotas pretty much for a living, could redo my pcm so it will be right. i have a pcm out of a 2004 corolla 5 speed, but with that pcm installed, my vibe wont start. i need to find someone that could either reflash my factory pcm to be a manual trans pcm or that could VIN flash the corolla pcm so my car will start and run. i need to find someone as close as possible to Ironton, Ohio, Huntington WV is close enough for a search. im pretty much relying on u guys to help me find someone, because ive looked all over around here and found nothing. this is the last thing i need to do to have my vibe 100% done. i absolutely NEED all the help that can be given right now with this. any leads will be greatly appreciated
Re: NEED PCM HELP!!!!
Posted: Fri Jul 06, 2012 10:31 pm
by star_deceiver
You could try giving your local GM dealer a call, in theory they should have all the tools to do it.
Hunt around at the wreckers for a Vibe GT or call around for a PCM.
