::GeoffGT's Garage:: 2009 Red Hot Metallic GT
Posted: Fri Jun 15, 2012 5:27 pm
by GeoffGT
This is right after I bought the car.
The dual-tone Wolo horns, painted red.
Just a little red paint under the hood.
Got the windows tinted. I forget what percentage but it is the same all around.
K&N Typhoon installed.
GM Window visors. I went with these for the nonfunctional but cosmetic "3rd" window. Continuity is my friend.
Custom ScanGaugeII install.
Random shot.
Re: ::GeoffGT's Garage:: 2009 Red Hot Metallic GT
Posted: Sat Jun 16, 2012 4:18 pm
by vibenvy
Glad to see you're back Geoff :)! I'm looking forward to seeing more pictures of your Vibe again! Have you done anything new to it lately?
Posted: Mon Jun 18, 2012 1:15 pm
by journeyforce
I like how you mounted that ScangaugeII. How do you have the cord to the OBD2 connector routed? I got a cheaper scan tool. I got the Ultragauge since I could not justify spending $150 for the SGII when I could get this one for $69 and it does what I needed to do. I have a 2012 Scion XB and Toyota went cheap and dropped the temp gauge for a full time clock. I got this Ultragauge just for the temp and battery voltage
Here is a pic of mine in my XB
Keep up the good work on your car
Posted: Wed Jun 20, 2012 10:23 am
by GeoffGT
Hey it's good to be back Carrie! Thanks. I haven't done much lately. I did paint the calipers though. But that's about it. I did the gold color. Wanted something different than red or yellow. :D
Thanks for the kind words Journeyforce. My buddy did the custom install on the SG2. The cable is routed under the dash to the OBD2 port; it's basically just tucked up behind everything. In hindsight, I wish the gauge was angled toward me just a bit, but oh well. I like the display on your gauge! Very clean.
Posted: Fri Jul 06, 2012 12:32 pm
by GeoffGT
Gold calipers
LED strips on my buddy's 4-Runner and my Vibe
Posted: Thu Sep 19, 2013 11:50 am
by Derf
LED Hood lights,... :D drat another thing I will have to add to my to do list!
Did you use a tilt switch, or jare they on a manually operated toggle switch.
Posted: Fri Sep 20, 2013 7:28 pm
Looking good Geoff ;) You can never go wrong with LED lighting .... even if it's under the hood! Keep up the good work!
