How many minutes off is your clock ?
Posted: Wed May 30, 2012 4:13 pm
by 808 Vibes
Mine (the Monsoon 6 CD option) was off by 5 or 6 minutes, I set it correctly, and it's still off. :x Note to self: the next time I bother to set it to the "correct" time, I should set it for two minutes ahead. :lol:
Re: How many minutes off is your clock ?
Posted: Wed May 30, 2012 5:04 pm
by KITT222
My bathroom clock is fast by who knows how many minutes. My car clock isn't even used. I wear a watch I synced to my school clocks, but my Vibe clock should be dead-on. That's a weird thing with the factory Vibe radio, though. Even if you set the time right, it'll be off within a week. It's happened a few times back when I had my OE radio.
Posted: Wed May 30, 2012 5:19 pm
by jake75
The clock in my '09 Vibe gains time. Maybe a minute or so per month.
Posted: Thu May 31, 2012 9:17 am
by ehoff121
I use the radio signal update feature and find that it is usually pretty accurate between updates.
The 2005 Moon & Tunes single CD unit allows you to use an FM radio station that is broadcasting time info (i.e., radio display shows "INFO" lit) to update the clock by pressing and holding the HR & MN buttons at the same time.
Posted: Thu May 31, 2012 1:12 pm
by MrHatchWagon
My Kenwood reads 60 minutes late, because I forgot how to set the clock when we sprang forward for spring.
Posted: Thu May 31, 2012 7:35 pm
by 09vGT
Mine keeps time almost perfectly. Maybe falling behind close to or one minute in a six month time period.
Posted: Sat Jun 02, 2012 7:12 pm
by crazytrain
09vGT wrote:Mine keeps time almost perfectly. Maybe falling behind close to or one minute in a six month time period.
Similar here, but might be closer to 4-5 months. Stock radio w/ CD player.
Posted: Sat Jun 02, 2012 9:45 pm
by star_deceiver
It works... may be off a minute or two either way. Don't know for sure as I haven't compared it to anything other then the clock at work.
Posted: Sun Jul 08, 2012 5:40 pm
by PearHunter
By the time it's time to change the clocks, I'm off by a good 10 minutes. Never fails.
Posted: Sun Jul 08, 2012 6:44 pm
by jake75
PearHunter wrote:By the time it's time to change the clocks, I'm off by a good 10 minutes. Never fails.
Ahead or behind?
